przez Misiek » 24 września 2018, 21:44
Maćkoleon, na pewno jeden kabel do licznika a drugi chyba do masy. Masz tu rozpiskę pinów wtyczki licznika.
Dodatkowo opis PINów złącza licznika:
1 - Ignition terminal 15
2 - Power supply, terminal 30
3 - not occupied
4 - Fog lights
5 - Brake fluid
6 - Park brake
7 - Transponder 1
8 - Transponder 2
9 - not occupied
10 - not occupied
11 - not occupied
12 - Can instrument panel Low
13 - Can instrument panel High
14 - Dash panel earth
15 - Wakeup
16 - not occupied
17 - Fuel gauge, full
18 - Fuel gauge, empty
19 - Earth terminal 31
20 - not occupied
21 - not occupied
22 - Worn brake pads
23 - not occupied
24 - not occupied
25 - Oil pressure
26 - Oil temperature
27 - not occupied
28 - Speedometer signal output
29 - Speedometer signal input
30 - Data -time
31 - Earth -time
32 - Supply - time
33 - Earth sensors 31
34 - Clean water
35 - Coolant temperature and coolant shortage warning lamp K28
36 - Exterior temp. sensor
Był świetny F
R STYLE 2.0 T
DI+ by
DYNOSOFT
LeonJest nowy 5F'ST
FR1.8 TSI My2018
Leon
