bledy VAG
bledy VAG
Postprzez 666damian » 12 lutego 2009, 20:36
Witam jestem nowym uzytkownikiem forum i poczatkujacym forumowiczem
prosilbym o skomentowanie bledow VAG
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 038 906 012 FK
Component: 1,9l R4 EDC 0000SG 3357
Coding: 00002
Shop #: WSC 06441
VSSZZZ1MZ2R051295 SEZ7Z0A1385883
3 Faults Found:
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-10 - - - Intermittent
17552 - Mass Air Flow Sensor (G70): Open or Short to Ground
P1144 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 00001
No fault code found.
Address 08 -------------------------------------------------------
Controller: 1M0 820 043 D
Component: 1M-CLIMATRONIC X0605
Coding: 00044
Shop #: WSC 06441
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1M0 920 902 D
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 05422
Shop #: WSC 00000
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to B+ - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06441
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 F
Component: 3M Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 06441
2 Faults Found:
01135 - Interior Monitoring Sensors
36-00 - Open Circuit
00929 - Locking Module for Central Locking: Front Passenger Side (F221)
27-10 - Implausible Signal - Intermittent
End -------------------------------------------------------h
UWAGA!!!! Prosze o przeniesienie do dzialu LEON 1 Diesel, przepraszam ale nie spojrzalem i zle wpisalem!!!!!!!
666damian
666damian
Dołączył(a): 17 stycznia 2009, 20:04
Re: bledy VAG
Postprzez Axee » 13 lutego 2009, 00:17
666damian, tak na szybko (o wszystkim bylo na forum, uzyj szukajki):
(01) silnik
turbo przeladowuje, zlapales notlauf (silnik w trybie awaryjnym) -> zapieczone kierowniczki, zaworek N75, uszkodzona gruszka, rurki podcisnienia.
wlacznik przy pedale hamulca uszkodzony -> wymienic wlacznik swiatel stop przy pedale hamulca
przeplywomierz przerwa lub zwarcie z masa -> sprawdzic styki, wiazke, ew. uszkodzona przeplywka do wymiany.
(17) zegary
czujnik temp. przerwa lub zwarcie z plusem -> wymienic podwojny czujnik temperatury przy silniku
(46) modul komfortu
czujniki ruchu od alarmu przerwa -> sprawdzic podlaczenie tylnych lampek i czy sa one z czujnikami ruchu, ew. kostki i wiazke tez sprawdzic.
zamek centalny drzwi przednie pasazera uszkodzenie -> sprawdzic mikroprzelaczniki wewnatrz kasety zamka, sprawdzic zlaczke el. i luty laczace ja z plytka, czy nie wyrwane, ew. spr. wiazke drzwi.
