Brak mocy/spadek mocy
Witam, brak mocy 1.9 tdi 110km asv, na komputerze pojawia się błąd przepływomierza masowego, po usunięciu błędu przez chwile jest dobrze, i błąd powraca.
Logi przepływomierza i turbiny.
Da się coś z tego odczytać? robiłem to 1szy raz.
Monday,19,April,2021,14:20:01
038 906 012 FK ,,1.9l R4 EDC 0000SG 3357,
,Group A:,'003,,,,Group B:,'011,,,,Group C:, Not Running
,,Engine speed,MAF (specified),MAF (actual),EGR duty cycle,,Engine speed,Specified MAP,Actual MAP,D.cycle MAP v.,,,,,
,TIME,870-950 rpm,230-370 mg/H,230-370 mg/H,40-75%,TIME,rpm,1850-1950 mbar,1700-2080 mbar,45-95%,TIME,,,,
MARKER,STAMP, /min, mg/R, mg/R, %,STAMP, /min, mbar, mbar, %,STAMP,,,,
,0.02,1932,850.0,290.0,19.9,0.33,1953,1091.4,1193.4,53.4,,,,,
,0.68,1974,850.0,285.0,19.9,1.01,2037,1173.0,1213.8,53.4,,,,,
,1.36,2079,850.0,315.0,19.9,1.70,2142,1173.0,1315.8,59.8,,,,,
,2.06,2205,850.0,325.0,19.9,2.41,2268,1173.0,1366.8,63.8,,,,,
,2.76,2310,850.0,315.0,19.9,3.10,2352,1173.0,1336.2,64.1,,,,,
,3.46,2415,850.0,310.0,19.9,3.79,2457,1173.0,1326.0,64.9,,,,,
,4.14,2499,850.0,305.0,19.9,4.48,2541,1162.8,1326.0,65.7,,,,,
,4.84,2268,850.0,295.0,4.8,5.17,1848,999.6,1315.8,31.1,,,,,
,5.52,1365,850.0,285.0,4.8,5.86,1617,1060.8,1224.0,36.7,,,,,
,6.20,1638,850.0,315.0,19.9,6.56,1680,1203.6,1387.2,49.0,,,,,
,6.89,1722,850.0,375.0,19.9,7.23,1764,1213.8,1642.2,63.4,,,,,
,7.58,1806,850.0,390.0,19.9,7.91,1827,1213.8,1540.2,66.9,,,,,
,8.26,1890,850.0,345.0,19.9,8.62,1911,1213.8,1397.4,61.0,,,,,
,8.96,1953,850.0,340.0,19.9,9.29,1995,1224.0,1387.2,61.4,,,,,
,9.64,2016,850.0,340.0,19.9,9.98,2058,1224.0,1397.4,63.0,,,,,
,10.32,2100,850.0,340.0,19.9,10.66,2121,1234.2,1417.8,64.9,,,,,
,11.00,2163,850.0,350.0,19.9,11.33,2184,1244.4,1458.6,68.1,,,,,
,11.68,2226,850.0,355.0,19.9,12.01,2268,1254.6,1479.0,70.9,,,,,
,12.36,2310,850.0,360.0,19.9,12.70,2331,1254.6,1509.6,72.9,,,,,
,13.03,2373,850.0,365.0,19.9,13.38,2394,1254.6,1540.2,75.3,,,,,
,13.73,2436,850.0,370.0,19.9,14.09,2457,1254.6,1560.6,79.3,,,,,
,14.44,2478,850.0,370.0,19.9,14.78,2520,1254.6,1581.0,81.7,,,,,
,15.12,2562,850.0,370.0,19.9,15.48,2583,1264.8,1591.2,84.5,,,,,
,15.84,2625,850.0,370.0,19.9,16.17,2646,1264.8,1601.4,87.7,,,,,
,16.52,2667,850.0,365.0,19.9,16.86,2688,1264.8,1581.0,89.3,,,,,
,17.20,2730,850.0,360.0,19.9,17.54,2751,1275.0,1560.6,89.6,,,,,
,17.87,2772,850.0,345.0,19.9,18.18,2793,1275.0,1540.2,90.4,,,,,
,18.54,2814,850.0,340.0,19.9,18.89,2835,1285.2,1519.8,90.0,,,,,
,19.24,2835,850.0,335.0,19.9,19.58,2856,1285.2,1499.4,91.2,,,,,
,19.91,2877,850.0,325.0,19.9,20.25,2856,1030.2,1479.0,92.0,,,,,
,20.60,2520,850.0,300.0,4.8,20.93,2016,999.6,1397.4,31.1,,,,,
,21.28,1533,850.0,280.0,4.8,21.61,2016,1101.6,1275.0,50.2,,,,,
,21.96,1953,850.0,360.0,19.9,22.32,1953,1234.2,1621.8,62.6,,,,,
,22.66,1974,850.0,430.0,19.9,23.00,1995,1234.2,1744.2,75.7,,,,,
,23.34,1995,850.0,365.0,19.9,23.69,2016,1234.2,1458.6,65.7,,,,,
,24.04,2037,850.0,335.0,19.9,24.37,2037,1234.2,1377.0,61.4,,,,,
,24.71,2058,850.0,330.0,19.9,25.06,2058,1234.2,1356.6,61.4,,,,,
,25.40,2079,850.0,325.0,19.9,25.76,2100,1234.2,1356.6,61.8,,,,,
,26.12,2100,850.0,330.0,19.9,26.46,2121,1234.2,1356.6,62.6,,,,,
,26.81,2121,850.0,325.0,19.9,27.16,2142,1234.2,1366.8,63.0,,,,,
,27.50,2163,850.0,325.0,19.9,27.83,2163,1234.2,1377.0,64.5,,,,,
,28.18,2184,850.0,325.0,19.9,28.51,2184,1244.4,1377.0,65.7,,,,,
,28.86,2205,850.0,335.0,19.9,29.20,2205,1244.4,1387.2,66.9,,,,,
,29.54,2205,850.0,330.0,19.9,29.90,2226,1244.4,1387.2,68.1,,,,,
,30.25,2247,850.0,330.0,19.9,30.60,2247,1244.4,1397.4,69.3,,,,,
,30.95,2268,850.0,330.0,19.9,31.29,2268,1244.4,1397.4,70.5,,,,,
,31.65,2289,850.0,330.0,19.9,31.98,2289,1244.4,1407.6,71.3,,,,,
,32.32,2289,850.0,330.0,19.9,32.66,2310,1254.6,1417.8,72.1,,,,,
,33.00,2331,850.0,335.0,19.9,33.35,2331,1264.8,1417.8,72.9,,,,,
,33.68,2331,850.0,335.0,19.9,34.02,2352,1264.8,1417.8,74.1,,,,,
,34.36,2352,850.0,335.0,19.9,34.70,2373,1264.8,1428.0,74.9,,,,,
,35.04,2373,850.0,335.0,19.9,35.40,2394,1254.6,1428.0,76.1,,,,,
,35.73,2394,850.0,335.0,19.9,36.08,2415,1254.6,1428.0,77.3,,,,,
,36.42,2415,850.0,335.0,19.9,36.76,2436,1264.8,1428.0,78.1,,,,,
,37.09,2436,850.0,335.0,19.9,37.45,2457,1254.6,1438.2,79.3,,,,,
,37.79,2457,850.0,335.0,19.9,38.14,2478,1254.6,1438.2,80.5,,,,,
,38.48,2478,850.0,335.0,19.9,38.82,2499,1213.8,1438.2,81.7,,,,,
,39.19,2289,850.0,300.0,4.8,39.54,1890,999.6,1346.4,31.1,,,,,
,39.87,1407,850.0,280.0,4.8,40.21,1029,999.6,1224.0,19.9,,,,,
,40.57,1029,850.0,250.0,19.9,40.90,1533,1040.4,1173.0,36.7,,,,,
,41.25,1890,850.0,320.0,19.9,41.60,1911,1111.8,1428.0,58.6,,,,,
,41.93,1911,850.0,345.0,19.9,42.28,1911,1111.8,1417.8,63.0,,,,,
,42.62,1911,850.0,295.0,19.9,42.96,1911,1111.8,1254.6,55.4,,,,,
,43.32,1911,850.0,285.0,19.9,43.68,1911,1111.8,1203.6,53.0,,,,,
,44.02,1911,850.0,280.0,19.9,44.36,1911,1081.2,1193.4,53.0,,,,,
,44.70,1911,850.0,275.0,19.9,45.03,1911,999.6,1193.4,32.3,,,,,
,45.38,1890,850.0,265.0,4.8,45.72,1869,999.6,1193.4,31.1,,,,,
,46.06,1848,850.0,270.0,4.8,46.40,1848,999.6,1213.8,30.7,,,,,
,46.74,1806,850.0,265.0,4.8,47.07,1764,999.6,1224.0,30.3,,,,,
,47.42,1722,850.0,265.0,4.8,47.76,1680,999.6,1213.8,29.9,,,,,
,48.10,1638,850.0,265.0,4.8,48.44,1596,999.6,1203.6,29.1,,,,,
,48.78,1554,850.0,255.0,4.8,49.12,1512,999.6,1193.4,28.3,,,,,
,49.46,1449,850.0,255.0,4.8,49.80,1407,999.6,1173.0,27.9,,,,,
,50.14,1344,850.0,255.0,4.8,50.48,1029,999.6,1162.8,19.9,,,,,
,50.82,966,850.0,255.0,19.9,51.18,924,999.6,1122.0,19.9,,,,,
,51.52,882,850.0,235.0,19.9,51.85,882,999.6,1091.4,19.9,,,,,
,52.20,903,850.0,235.0,19.9,52.54,903,999.6,1081.2,19.9,,,,,
,52.87,903,850.0,240.0,19.9,53.22,882,999.6,1071.0,19.9,,,,,
,53.55,882,850.0,240.0,19.9,53.89,903,999.6,1071.0,19.9,,,,,
,54.24,903,850.0,240.0,19.9,54.59,903,999.6,1071.0,19.9,,,,,
,54.95,903,850.0,240.0,19.9,55.29,903,999.6,1071.0,19.9,,,,,
,55.64,924,850.0,235.0,19.9,55.98,1239,999.6,1071.0,19.9,,,,,
,56.32,1302,850.0,265.0,19.9,56.65,1281,1040.4,1142.4,36.7,,,,,
,57.00,1302,850.0,280.0,19.9,57.34,1323,1060.8,1224.0,36.7,,,,,
,57.67,1365,850.0,290.0,19.9,58.02,1386,1060.8,1285.2,36.7,,,,,
,58.37,1428,850.0,300.0,19.9,58.72,1449,1040.4,1326.0,36.7,,,,,
,59.05,1449,850.0,300.0,19.9,59.41,1449,1009.8,1326.0,29.5,,,,,
,59.74,1470,850.0,290.0,19.9,60.08,1449,1009.8,1305.6,29.5,,,,,
,60.42,1449,850.0,290.0,19.9,60.76,1449,1009.8,1295.4,29.5,,,,,
,61.12,1449,850.0,285.0,19.9,61.46,1470,1020.0,1295.4,29.9,,,,,
,61.80,1470,850.0,290.0,19.9,62.14,1470,1020.0,1295.4,29.9,,,,,
,62.48,1491,850.0,295.0,19.9,62.81,1491,1030.2,1305.6,33.5,,,,,
,63.14,1491,850.0,300.0,19.9,63.48,1512,1040.4,1326.0,37.1,,,,,
,63.81,1533,850.0,300.0,19.9,64.14,1533,1040.4,1346.4,37.5,,,,,
,64.47,1575,850.0,305.0,19.9,64.79,1596,1040.4,1366.8,38.3,,,,,
,65.14,1617,850.0,315.0,19.9,65.48,1638,1060.8,1397.4,39.4,,,,,
,65.82,1680,850.0,325.0,19.9,66.16,1701,1060.8,1448.4,40.6,,,,,
,66.50,1722,850.0,330.0,19.9,66.84,1764,1060.8,1489.2,41.4,,,,,
,67.18,1785,850.0,340.0,19.9,67.52,1827,1060.8,1519.8,42.2,,,,,
,67.87,1722,850.0,335.0,4.8,68.22,1365,999.6,1438.2,27.9,,,,,
,68.56,1029,850.0,275.0,19.9,68.90,987,999.6,1224.0,19.9,,,,,
,69.23,924,850.0,250.0,19.9,69.59,903,999.6,1142.4,19.9,,,,,
,69.93,903,850.0,245.0,19.9,70.28,903,999.6,1091.4,19.9,,,,,
,70.62,903,850.0,240.0,19.9,70.96,903,999.6,1081.2,19.9,,,,,
,71.32,903,850.0,235.0,19.9,71.68,882,999.6,1071.0,19.9,,,,,
,72.03,882,850.0,245.0,19.9,72.38,882,999.6,1071.0,19.9,,,,,
,72.72,882,850.0,240.0,19.9,73.05,882,999.6,1071.0,19.9,,,,,
,73.40,882,850.0,240.0,19.9,73.74,882,999.6,1071.0,19.9,,,,,
,74.07,882,850.0,235.0,19.9,74.42,882,999.6,1060.8,19.9,,,,,
,74.76,882,850.0,235.0,19.9,75.10,903,999.6,1071.0,19.9,,,,,
,75.46,903,850.0,235.0,19.9,75.80,903,999.6,1060.8,19.9,,,,,
,76.16,903,850.0,235.0,19.9,76.50,903,999.6,1060.8,19.9,,,,,
,76.84,903,850.0,240.0,19.9,77.17,903,999.6,1060.8,19.9,,,,,
,77.51,882,850.0,240.0,19.9,77.85,903,999.6,1060.8,19.9,,,,,
,78.17,882,850.0,235.0,19.9,78.51,903,999.6,1060.8,19.9,,,,,
,78.85,903,850.0,235.0,19.9,79.17,903,999.6,1060.8,19.9,,,,,
,79.51,903,850.0,240.0,19.9,79.83,903,999.6,1060.8,19.9,,,,,
,80.15,882,850.0,235.0,19.9,80.49,882,999.6,1060.8,19.9,,,,,
,100.58,903,850.0,235.0,19.9,100.26,903,999.6,1060.8,19.9,,,,,
,101.25,903,850.0,240.0,19.9,100.92,903,999.6,1060.8,19.9,,,,,
,101.94,903,850.0,240.0,19.9,101.60,903,999.6,1060.8,19.9,,,,,
1,102.65,903,850.0,235.0,19.9,102.30,903,999.6,1060.8,19.9,,,,,
,103.32,903,850.0,235.0,19.9,102.98,903,999.6,1060.8,19.9,,,,,
,103.99,903,850.0,240.0,19.9,103.66,903,999.6,1060.8,19.9,,,,,
