Akcja serwisowa Seata z 28wrz2016: Update softu Infotainment
Poszukujac informacji na temat swojej Navi i mozliwosci jej aktualizacji zalogowalem sie na SEAT erWin.
Tam znalazlem pare ciekawych informacji + informacje na temat akcji serwisowej z datą ogloszenia ogloszenia - 28 wrzesnia 2016.
Czy ktos z Was mial juz ten update zrobiony w ASO?
Brak jest informacji co nowy soft zmienia.
Szczegoly akcji po angielsku:
Technical product information Service notification: 9196, Infotainment system update process using an SD card Release date: 28-Sep-2016
Customer statement / workshop findings Customer statement:
•Various claims regarding the Infotainment unit. Workshop findings:
•The Infotainment unit software must be updated.
Technical background
Warning: These instructions for the software update are valid for units with PR numbers: I8D, I8E, I8F, I8G, I8H, I8J. Check the original part reference for the software update medium (SD card) in the corresponding publication.
Measure Infotainment system update process using an SD card
Important: The images included below are for information purposes only.
The contents (text, etc.) may differ from those shown here. Safety measures for the software update: •Make sure that the resting voltage of the vehicle's battery is at least 12.5 V. A charger must be connected to the battery in order to maintain the on-board voltage throughout the software update. •Disconnect all unnecessary electrical components in the vehicle. During the software update leave all electrical components disconnected. •Do not simultaneously perform a diagnosis with vehicle diagnostics equipment. •The ignition must be connected on during the entire software update. •The engine must not be started during the software update. •Make sure no electromagnetic sources (e.g. mobile phones or wireless DECT phones) are used in the vehicle or near it while updating the software. •The software update is done through an SD card reader inserted in the Infotainment unit.
Software update procedure:
Step 1: Connect the Infotainment unit.
Step 2: Insert the software update medium (SD card) in the Infotainment unit card reader.
Step 3: Press the Menu key for 5 seconds to access the Service mode, see Figure 2 Mark 1.
Figure 1: Location of the MENU key.
Step 4: Select the Download Software/Versions option, see Figure 2 Mark 2.
Figure 2: View of the display with the Service mode menu and the Download software/versions option. Key to Figure 2: 1: Service mode. 2: Download software/versions option.
Step 5: In the next menu, select Update, see Figure 3.
Figure 3: View of the “Update” option in the Download software menu.
Step 6: Select the source of the data, in this case SD card, see Figure 4.
Figure 4: View of the SD card option in the Select source menu.
Step 7: Select the software version indicated for the Infotainment unit to be updated. Example in Figure 5.
Figure 5: View of an example of the image show in the Infotainment display to select the software update.
Figure 5 A: Do not use the unit and wait while the system loads that data.
Step 8: Press the Start button on the touch screen, see Figure 6.
Figure 6: View of the Start option.
Step 9: Read and confirm the informational text by pressing Next. See Figure 7.
Figure 7: View of an important message, it is essential to confirm it.
Step 10: The update process lasts approximately 60 minutes and cannot be interrupted. During the software update the Infotainment unit restarts several times. The text shown in Figure 8 can appear several times.
Figure 8: During the update the message highlighted in the red box will appear several times. It is important to follow the Software Update Safety Measures described above.
Step 11: Once the software update has finished successfully, a window with the text Software Download: Result will appear, as well as the Update Summary text.
Figure 9: View of the infotainment unit after finishing the software update.
Step 12: Next, an indication of the compulsory data transmission for the software update that has been performed will display. It will have the following fault code registered: •B201A00: Software version management test. Delete the registered fault code.
To do this, connect the ODIS (Offboard Diagnostic Information System Service) diagnostics equipment and perform the LGA as follows: Instructions for documenting the version:
•Selection of the affected vehicle •Complete vehicle system test: run.
•Test Plan
•Own test
•Software version management (SVM)
•Special measures
•5F – Select information electronics 1 / J794.
•5F - Check the current version/Restart the fault memory
Step 13: Lastly, restart the Infotainment unit. Next, remove the software update medium (SD card) from the card reader.
Warning: The software update medium (SD card) must not be left in the vehicle (in the customer’s possession).
•Test Plan
•Own test
•Special measures
