cinek1006 napisał(a):bardzo proszę o sprawdzenie nr VIN
VSSZZZ1MZ5R020665
Nr nadwozia VSSZZZ1MZ5R020665
model leon top
LE
Data produkcji 31.08.2004
Rok modelowy 2005
typ handlowy 1M1736
numer silnika AUQ
numer skrzyni biegów FZQ
numer napedu osiowego 6S
Wyposazenie EC
kolor dachu 1V
kolor zewnetrzny / numer koloru 1V / S1H
Activated carbon canister 1E1 Activated carbon canister
Additional body covers, side 6EB Additional body covers, stone guard and
partial trim plate
Additional child seat anchors 3B0 Without additional child seat anchor
Additional tires (winter tires) 2WA Without additional tires
Additional tunnel cover 4J5 Floor tray, extension center console
Additional warning lights 9TB Additional warning lights (door area)
Air bag 4UF Driver's and front passenger air bag
with front passenger air bag
deactivation
Antennas 8L3 Roof antenna
Anti-theft protection system 7AA Electronic vehicle immobilization device
Antifreeze 1C1 Antifreeze up to -25 degree celsius
tolerance up to -30 degree C
Automatic transmission indicator light 9FA Without automatic transmission
indicator light
Auxiliary heating 9M0 Without auxiliary/parking heater
Backrest release 3H0 Without backrest release for front seats
Base engine T8C 4-cylinder gasoline engine 1.8 L
unit 06A.C
Batteries J1L Battery 280 A (60 Ah)
Body measures 5C0 Without special body measures
Body style K8G Hatchback
Brackets 3P1 Bracket for first aid kit and warning
triangle
Brake pad wear indicator 9U1 Brake pad wear indicator
Brake type, front 1LJ Disc brakes, front
Brake type, rear 1KP Disc brakes, rear
Braking systems 1AJ Anti-spin regulation (ABS/ASR/EDL) with
electronic differential lock (EDL)
Breakaway interior mirror 4L2 Dipping breakaway interior rear view
mirror
Bumper 2JK Sports bumpers
Carrier frequency for radio remote control 5D1 Carrier frequency 433.92 MHz-434.42 Mhz
Cassette and CD storage unit 4W0 Without cassette and CD storage unit
Catalytic converter control 8KA W/o catalytic converter warning light
CD changer/CD player 7A0 Without CD changer/CD player
Cd enhancing underbody panel 2D1 Complete cd enhancing underbody panel
CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
Center armrest 6E3 Front center armrest
Center rear seat belts 3C7 3-point seat belt for center rear seat
Child seats QA0 Without child seat
Component part sets with country-specific design requirements B0V Component parts set, complying with
vehicle type for the Netherlands
various parts
Components with special surface appearance 6FH Exterior mirror housings painted
Controls (steering wheels/steering column) 4LA Without controls
Cruise control 8T2 Cruise control system (CCS)
electronic
Cruise control warning and speed limit system 6Y0 Without cruise control warning system
Cup holder 4M5 Cup holder
Dashboard 4N1 Padded dashboard
Door and lid locking system 4K3 Radio remote controlled central locking
operated from inside and safe securing
Door and side trim panels 4AF Door and side trim panel in foam film
and woven fabric
Door pockets, front 3YQ Door pockets without insert mats
Doors 0A2 4 doors
Drive layout 1X0 Front wheel drive
Electronic map cooling system QS0 Without electronic map cooling system
Emission standard 0GG Emission standard EU4
Engine cooling system 8Z5 Not hot country
Engine specifications MQ7 4-cyl. gasoline engine 1.8 L/132 kW 20V
turbo
base engine is T8C/T16/T63
Equipment levels A9R Top sports
Exterior mirror setting 6XE Exterior mirrors: electrically foldable
and electrically adjustable/heated
Exterior noise suppression measures 2B1 Additional exterior noise suppression
Fire extinguisher 6A0 Without fire extinguisher
First aid kit / warning triangle 1T0 Without first aid kit and warning
triangle
Flame retardent materials 4Q1 Flame retardent materials
Floor mats 0TA Without floor mats
Fresh air intake for passenger compartment (with particulate filter) 2V1 Dust and pollen filter
Front fog light/additional headlight 8WD Integrated front fog light
Front license plate carrier 6W0 Without license plate carrier front
Front seats Q4H Comfort sports seats, front
Front stabilizer 0AE Front stabilizer
Front underbody guard 1SA Without additional front underbody guard
Fuel filler cap/door, locking option 2W0 Fuel filler cap
Fuel quantity for initial filling 1Z0 Initial standard fuel filling
Fuel systems 0F2 Fuel system for carburetor gasoline
engine
Fuel tank treatment 2LB Fuel tank with special material
treatment
Gearshift boot/cover 6R2 Leather gearshift boot
Gearshift knob/handle 7F4 Sports gearshift knob
General operating permit, alterations C25 Operating permit, alteration
Generators 8GL Alternator 120 A
Grab handles at roof frame 5N6 Folding grab handles at roof frame
soft fold-away
Hand brake lever handle 6PA Plastic hand brake lever handle
Headlight 8BB Halogen headlight
for driving on the right
Headlight activation 8K0 Without special headlight
activation
Headlight washer system 8X0 Without headlight washer system
Headlight-range adjustment 8Q1 Headlight-range adjustment
Headphone port, rear 8MA Without headphone port rear
Headrests 3J7 Articulated and height-adjustable
headrests for front seats
Heat accumulator system/additional heater 7E0 W/o heat accumulator/auxiliary heating
Heated door lock cylinder 9X0 Without heated door lock cylinder
Heated rear window 8P1 Heated rear window
Heated washer nozzles 9T0 Without heated washer nozzles
Heating and air conditioning system 9AK Climatronic with impact pressure
control free of cfc
Horns 8Y1 Two-tone horn
Identification plates 1EX Special identification plate for EC
for M1 passenger vehicle
Ignition/starter switch locking system 0RA Without ignition/starter switch locking
system
Insert for the filling up of unleaded fuel/fuel type 2G9 Filler neck module 2 with insert
Inserts 5MJ Decorative inserts
Installation differentiation for vehicle components 0EN Installation differentiation for
transmission MQ 350
vehicle components
Instrument inserts U0C Instrument insert with tachometer
clock and km/h speedometer
Interference suppression 8E2 Local interference suppression for FM/AM
radio reception
Interior light in driver compartment 9GB Interior lamp with switch-off delay and
contact switch on the doors
Key for locking system 8QE Key for locking system
with remote control
Left exterior mirror 5SL Left exterior mirror: aspherical
Left vanity mirror 4SD Left vanity mirror, illuminated
Lock operation for tailgate/trunk lid 4E0 Tailgate/trunk lid unlocking
from outside
Lockable wheel bolts 1PC Wheel bolts with anti-theft protection
(unlockable)
Luggage compartment cover 3U1 Foldable trunk cover
Luggage compartment floor covering 6SC Tufted trunk floor covering
Luggage compartment lining 5A2 Comfort trunk lining
Luggage net/pocket on backrest(s) 4U3 Luggage net on backrest, right seat
Lumbar support 7P0 Without lumbar support
in seat backrests
Manufacturing sequence differentiation 0FA Standard manufacturing sequence
Mass damper for steering wheels 1Q0 Without mass damper for steering wheel
Molding roof liner 6NA Unsplit molding roof liner
Multi-function display/trip computer 9Q1 Multi-function display/on-board computer
Nameplate set 0QN Nameplate set "20V T"
Navigation device 7Q0 Without navigation device
Outdoor temperature gage 9Y1 Outdoor temperature gage
Outer rear seat belts 3ZM 3-point seat belts, outer rear
Owner's manuals 0VH Information kit in Dutch
Paint preservative/transit coating 5K1 Paint preservative (wax)
Park distance control 7X0 Without park distance control
Partition 3CA Without partition
Pillar lining 4XF Exterior pillar lining
design 2
Platform group class 7PB Platform group class 2
Platform module floor pan, rear 4P0 Rear floor panel module, type 1
Preparation for two-way radio installation 9D0 Without preparation for two-way radio
installation
Proportioning valve 1H0 Without proportioning valve
Protective side molding 4B2 Body-colored protective side molding
Radiator grille 6KA Radiator grille
Radios 8UE Radio with CD drive
Reading light 8S2 One reading light front, two reading
lights rear
Rear axle 0N5 Standard rear axle
Rear cargo area 3GA Without cargo area
Rear fog light 8TF Rear fog lights, left and right
Rear headrests 3Q6 Three rear headrests
Rear license plate carrier 6P0 Without license plate carrier rear
Rear seat catch 6QA Rear seat catch
Rear seats 3NC Rear seat bench/backrest, split folding
Rear spoiler 5J7 Body-colored rear spoiler (version 4)
Rear stabilizer 0BB Rear stabilizer
Rear window wiper and washer system 8M1 Rear window wiper and washer system
with intermittent control
Restraint systems, front 4QU 3-point seat belts front w/ tensioner
(electr.) and height adjustment
Right exterior mirror 5RQ Right exterior mirror: convex
Right vanity mirror 4TD Right vanity mirror illuminated
Roll-up sun screen for rear and side windows 3Y0 Without roll-up sun screen
Roof insert/convertible top 3FA Without roof insert (standard roof)
Roof rails/roof load rack 3S0 Without roof rails/roof load rack
Rough-road/sports version 2UA Standard design
Seat adjustment 3L1 Manual height adjustment for left front
seat
Seat belt check 9P0 Without seat belt reminder
Seat covering N2C Fabric seat covering
Seat heater 4A0 Without seat heater
Service interval prolongation QG2 No possibility of activating service
Shock absorption, chassis, front G99 Front shock absorption
Shock absorption, chassis, rear 1JE Rear sports shock absorption
Side air bag 4X1 Side air bag front
Side and rear windows 4KC Side and rear windows in heat-insulating
glass
Side lights 7R3 Side turn signal lights (white)
Smoking/non-smoking package 9JB Smoking package, ashtray front and rear
Socket 7B2 12-volt socket in luggage boot
Spare wheel/breakdown set 1G1 Space-saving spare wheel
Speaker installation 8RM 8 speakers (passive)
Special alarm systems 9A0 Without taxi alarm system
Special color trim 0UA Without special color trim
Special editions E0A No special edition
Special labels/plates 0SE Labels/plates in Dutch
Special registration measures 3M0 Without special measures
Speedometer cable and seal 8CC Speedometer sensor without seal
(electronic speedometer sensor)
Steering QZ4 Power steering (limited steering lift
mechanism)
Steering column systems 2C5 Axial and vertical adjustable steering
column
Steering system arrangement L0L Left-hand drive vehicle
Steering wheels 2PX Leather trimmed sports steering wheel
Sticker (customized or special edition) 0KA Without stickers and badges
Supertone system and tone sequence control 9J0 Without supertone system and tone
sequence control
Taillight assemblies 8SA Taillight assemblies, standard design
Telephone/telematics 9W0 W/o car phone preparation/installation
Throttle actuation 0L2 Electric throttle actuation
Tire suppliers V0A Tires w/o specification of tire brand
Tires H6L Tires 225/45 R17 91W
Tool kit and jack 1S1 Tool kit and jack
Trailer hitch 1D3 Trailer hitch
Transmission specifications G0K 6-speed manual transmission
Transmission types/gearshift mechanisms 0G4 Cable gearshift
Type approval countries/countries with special requirements B31 Type approval the Netherlands
Vehicle class differentiation units/platform components 0CK Vehicle class differentiation 1M0
Vehicle specifications F0A No special purpose vehicle, standard
equipment
Vehicle type AZ0 Vehicle with standard production scope
Washer fluid level indicator 8W1 Washer fluid level indicator
Weight category front axle L28 Suspension range 28
installation control only, no
requirement forecast
Weight category rear axle 0YZ Without determination of weight category
for rear axle
Wheel covers 1NL Covers for alloy wheels
Wheels CM3 Alloy wheels 7J x 17
Window regulator 4R4 Power windows with comfort operation and
circuit breaker
Windshield glass type 4GF Windshield in heat-insulating glass
Windshield wiper intermittent control/ light/rain sensor 8N4 Windshield wiper intermittent control
with potentiometer (four speeds)Hoja369 napisał(a):Również prosiłbym o rozkodowanie nr VSSZZZ1MZ3R006623
Nr nadwozia VSSZZZ1MZ3R006623
model leon stella
LE
Data produkcji 15.05.2002
Rok modelowy 2003
typ handlowy 1M13KC
numer silnika BCB
numer skrzyni biegów ERT
numer napedu osiowego 5S
Wyposazenie KG
kolor dachu Z4
kolor zewnetrzny / numer koloru Z4 / C9Z
Additional body covers, side 6EA Without additional side body covers
(stone guard)
Additional tunnel cover 4J2 Floor tray, extension center console
Additional warning lights 9TD Door warning lights front and reflectors
rear
deactivation
indicator light
Base engine T27 4-cylinder gasoline engine 1.6 L
unit 036.L
triangle
Brake pad wear indicator 9U0 Without brake pad wear indicator
Brake type, front 1LQ Front disc brakes with integrated
adapter
Brake type, rear 1KK Disc brakes, rear
Braking systems 1AC Anti-lock brake system (ABS)
mirror
Bumper 2JJ Painted bumpers with protective moldings
Center armrest 6E0 Without center armrest front
Component part sets with country-specific design requirements B0X Component parts set, complying with
vehicle type for Germany, various parts
Components with special surface appearance 6FB Body-colored exterior mirror housings
Cruise control 8T0 Without cruise control system (CCS)
and woven fabric
Doors 0A2 4 doors
Engine specifications D3H 4-cylinder gas. engine 1.6 L/77 kW (16V)
with multi-point injection
Base engine is T27/TL0/TT0/TV5
Equipment levels A8D Luxury equipment
Exterior mirror setting 6XB Exterior mirrors: adjustable from inside
Exterior noise suppression measures 2B7 Additional exterior noise suppression
triangle
engine
treatment
Gearshift knob/handle 6Q2 Leather gearshift knob/handle
General operating permit, alterations C17 Operating permit, alteration
Generators 8GD Alternator 90A
soft fold-away
activation
Heating and air conditioning system 9AB Manually controlled air conditioning
Horns 8Y0 Single-tone horn
system
Inserts 5TC Without decorative inserts
Installation differentiation for vehicle components 0EB Installation differentiation for
transmission MQ170
vehicle components
radio reception
Interior light in driver compartment 9GA Interior light with door pillar switches
with remote control
Left vanity mirror 4SC Left vanity mirror with cover
from outside
Lockable wheel bolts 1PA Standard wheel bolts
in seat backrests
Multi-function display/trip computer 9Q0 Without multi-function display/
on-board computer
Nameplate set 0NB Nameplate set in base trim
Owner's manuals 0VC Information kit in German
Paint preservative/transit coating 5K0 Without surface protection, with
additional transit coating
design 2
installation
Protective side molding 4B1 Protective side molding
Reading light 8S1 Reading light front
Rear spoiler 5J5 Body-colored rear spoiler (version 2)
Rear stabilizer 0BC Rear stabilizer
Right vanity mirror 4TC Right vanity mirror with cover
Seat adjustment 3L3 Manual height adjustment for front seats
Seat covering N2Z Seat covering for special editions
Service interval prolongation QG0 Without service interval prolongation
Shock absorption, chassis, front G22 Front shock absorption
Shock absorption, chassis, rear 1JD Rear shock absorption, basic design 2
glass
Socket 7B0 Without socket
Spare wheel/breakdown set 1G2 Steel spare wheel with original
equipment tires
Special editions E82 "Sporty Entry"
Special labels/plates 0SB Labels/plates in German
Steering 1N6 Power steering
column
sequence control
Tires H6S Tires 195/65 R15 V
Transmission specifications G0C 5-speed manual transmission
Transmission types/gearshift mechanisms 0G3 Gearshift linkage
Type approval countries/countries with special requirements B01 Type approval Germany
equipment
Weight category front axle L16 Suspension range 16
for rear axle
Wheels CU8 Alloy wheels 6J x 15
Window regulator 4R5 Power windows with comfort operation and
circuit breaker, mechanical window
regulators rear
P82
jolo napisał(a):Poprosiłbym o rozkodowanie, z góry dziękujęVSSZZZ1MZ4R007811
Nr nadwozia VSSZZZ1MZ4R007811
model leon sport
LE
Data produkcji 13.06.2003
Rok modelowy 2004
typ handlowy 1M1546
numer silnika ASZ
numer skrzyni biegów ERF
Wyposazenie BP
kolor dachu H2
kolor zewnetrzny / numer koloru H2 / S7U
Activated carbon canister 1E0 Without activated charcoal canister
(stone guard)
Additional tunnel cover 4J1 Floor tray, extension center console
deactivation
indicator light
Base engine T9J 4-cylinder diesel engine 1.9 L
unit 038.K
Batteries J0L Battery 340 A (70 Ah)
triangle
Brake type, front 1LE Disc brakes, front
Braking systems 1AT Electronic stabilization program (ESP)
mirror
Bumper 2JG Body-colored bumpers
Component part sets with country-specific design requirements B0K Component parts set, complying with
vehicle type for France, various parts
and woven fabric
Doors 0A2 4 doors
Emission standard 0GZ Emission standard EU3, diesel with EOBD
Engine specifications D3E 4-cyl. turbo diesel engine 1.9 L/96 kW
TDI with pump-jet injection system
Base engine is T9J
Equipment levels A8F Sports equipment
Exterior mirror setting 6XD Exterior mirrors: electrically
adjustable/heated
Exterior noise suppression measures 2B3 Additional exterior noise suppression
(hood, capsule and dash panel)
triangle
Fuel systems 0F9 Cooled fuel system for diesel engine
treatment
General operating permit, alterations C22 Operating permit, alteration
soft fold-away
activation
control free of cfc
system
Insert for the filling up of unleaded fuel/fuel type 2G8 Filler neck module 2 without insert
transmission MQ 350
vehicle components
radio reception
with remote control
from outside
(unlockable)
in seat backrests
Nameplate set 1DG Nameplate set "TDI"
Owner's manuals 0VB Information kit in French
design 2
installation
seat
glass
equipment tires
Special labels/plates 0SG Labels/plates in French
column
sequence control
Tires H6U Tires 205/55 R16 91W
Type approval countries/countries with special requirements B08 Type approval France
equipment
Weight category front axle L43 Suspension range 43
for rear axle
Wheels CG7 Alloy wheels 7J x 16
offset 42
circuit breaker
PH2
arknaw napisał(a):Również przyłączam się do prośby o rozkodowanie VIN: VSSZZZ1MZ2R065520
Nr nadwozia VSSZZZ1MZ2R065520
model leon sport
LE
Data produkcji 13.12.2001
Rok modelowy 2002
typ handlowy 1M1524
numer silnika ASV
numer skrzyni biegów EGS
Wyposazenie KJ
kolor dachu 7D
kolor zewnetrzny / numer koloru 7D / B5N
(stone guard)
Air bag 4UE Air bag for driver and front seat
passenger
indicator light
Base engine T8U 4-cylinder diesel engine 1.9 L
unit 038.G
triangle
Brake type, front 1LS Front disc brakes with integrated
adapter
mirror
CD changer/CD player 7A1 CD changer preparation
various parts
and woven fabric
Doors 0A2 4 doors
Emission standard 0GE Emission standard EU3
Engine specifications MN0 4-cyl. turbo diesel eng. 1.9 L/81 kW TDI
EU 3
base engine is T8U
triangle
Fuel systems 0F3 Fuel system for diesel engine
treatment
General operating permit, alterations C14 Operating permit, alteration
soft fold-away
activation
control free of cfc
system
Installation differentiation for vehicle components 0EJ Installation differentiation for
transmission MQ 250
vehicle components
radio reception
with remote control
from outside
(unlockable)
in seat backrests
Nameplate set 2VP Nameplate set "TDI" "I"
design 2
installation
Radios 8YE Radio for comfort-class vehicle
Right exterior mirror 5RU Right exterior mirror: convex
(large viewing field)
seat
Shock absorption, chassis, front G62 Front shock absorption
glass
Sill top/sill cover 5E2 Sill top with door cover
equipment tires
column
sequence control
equipment
for rear axle
Wheels C3X Alloy wheels 6J x 15
circuit breaker
PH2
Zawodowiec180 napisał(a):Witam, pomoże ktoś z rozkodowaniem numeru vin VSSZZZ1MZ1R071831. z góry dziekuje.
Nr nadwozia VSSZZZ1MZ1R071831
model leon sport
LE
Data produkcji 28.02.2001
Rok modelowy 2001
typ handlowy 1M1536
numer silnika AUQ
numer skrzyni biegów ERR
Wyposazenie KJ
kolor dachu Z4
(stone guard)
Additional dust seals 6U0 Without additional seals outside
passenger
Anti-theft protection system 9V7 Electronic vehicle immobilization device
with anti-theft alarm system and
passenger compartment control
indicator light
unit 06A.C
triangle
Breakaway interior mirror 4L6 Breakaway interior rear view mirror,
automatically dimming
Bumper 2JD Sports bumpers
and woven fabric
Doors 0A2 4 doors
turbo
triangle
engine
treatment
General operating permit, alterations C12 Operating permit, alteration
soft fold-away
activation
Headphone port, rear 8MB Headphone port rear
control free of cfc
system
transmission MQ 350
vehicle components
radio reception
with remote control
from outside
(unlockable)
in seat backrests
design 2
installation
lights rear
Service interval prolongation QG1 Service interval prolongation
glass
equipment tires
column
sequence control
equipment
Weight category front axle L31 Suspension range 31
for rear axle
Wheels C4P Alloy wheels 10J x 21
circuit breaker
Windshield wiper intermittent control/ light/rain sensor 8N3 Windshield wiper intermittent control
with rain sensor
P51
PH2
Kalbar napisał(a):Witam ! Proszę o rozkodowanie numeru VIN:
VSSZZZ1MZ2R001826
Nr nadwozia VSSZZZ1MZ2R001826
model leon sport
LE
Data produkcji 09.05.2001
Rok modelowy 2002
typ handlowy 1M1524
numer silnika ASV
Wyposazenie KJ
kolor dachu L1
kolor zewnetrzny / numer koloru L1 / S7N
(stone guard)
passenger
indicator light
unit 038.G
triangle
adapter
mirror
various parts
and woven fabric
Doors 0A2 4 doors
EU 3
base engine is T8U
triangle
treatment
General operating permit, alterations C13 Operating permit, alteration
soft fold-away
activation
control free of cfc
system
transmission MQ 250
vehicle components
radio reception
with remote control
from outside
(unlockable)
in seat backrests
design 2
installation
seat
glass
equipment tires
column
sequence control
equipment
for rear axle
circuit breaker
PE4
PH2 KLICHO napisał(a):Witam czy mógł by ktoś sprawdzić ten numer vin VSSZZZ1MZ2R055206
Nr nadwozia VSSZZZ1MZ2R055206
model leon signo
LE
Data produkcji 17.11.2001
Rok modelowy 2002
typ handlowy 1M1824
numer silnika ASV
Wyposazenie AX
kolor dachu N1
kolor zewnetrzny / numer koloru N1 / S7T
(stone guard)
passenger
indicator light
unit 038.G
triangle
adapter
electronic
and woven fabric
Doors 0A2 4 doors
EU 3
base engine is T8U
Equipment levels A8W Luxury equipment
triangle
Front seats Q1A Standard front seats
treatment
Gearshift boot/cover 6R1 Leatherette gearshift boot
Gearshift knob/handle 6Q4 Comfort gearshift knob/handle
soft fold-away
activation
control free of cfc
system
transmission MQ 250
vehicle components
radio reception
with remote control
from outside
(unlockable)
in seat backrests
design 2
installation
seat
Seat covering N7C Fabric seat covering
Shock absorption, chassis, front G25 Front shock absorption
Shock absorption, chassis, rear UB5 Rear shock absorption for sports design
glass
equipment tires
column
Steering wheels 1MF Comfort steering wheel for air bag
system
sequence control
equipment
Weight category front axle L20 Suspension range 20
for rear axle
circuit breaker
with rain sensor
wrzoslaw91 napisał(a):itam czy ktoś by mi mógł sprawdzić nr vin :vsszzz1mzyb079835
Nr nadwozia VSSZZZ1MZYB079835
model leon signo
LE
Data produkcji 17.02.2000
Rok modelowy 2000
typ handlowy 1M1824
numer silnika ASV
numer skrzyni biegów EBF
Wyposazenie VQ
kolor dachu 3D
kolor zewnetrzny / numer koloru 3D / S5N
(stone guard)
passenger
Anti-theft protection system 7AB Electronic alarm system with vehicle
immobilization device (for RoW)
indicator light
unit 038.G
Batteries J0R Battery 380 A (80 Ah)
triangle
adapter
Cup holder 4M0 Without cup holder
Dashboard illumination 7V0 Standard dashboard illumination
Door and side trim panels 4AB Door and side trim panel partially in
leather
Doors 0A2 4 doors
Emission standard 7CA Emission standard LEV 3/Tier 3 160
Engine compartment lighting 9L0 Without engine compartment lighting
EU 3
base engine is T8U
Exterior mirror setting 6XF Exterior mirrors: with memory function,
electrically foldable/adjustable/heated
triangle
Front stabilizer 0AL Front stabilizer
treatment
General operating permit, alterations C05 Operating permit, alteration
soft fold-away
activation
Headlight washer system 8X1 Headlight washer system
Heat accumulator system/additional heater 7E3 Sheathed type glow plug heater
Heated washer nozzles 9T1 Heated washer nozzles, front
control free of cfc
system
radio reception
with remote control
from outside
Lumbar support 7P4 Manually adjustable lumbar support in
front seats
Manufacturing sequence differentiation 0FC Brussels manufacturing sequence
Preparation for sound combination for rotating emergency light 9F0 Without sound combination for rotating
emergency light and radio antenna
preparation
installation
Rear axle 0N1 Standard rear axle
Seat adjustment 3L4 Electric seat adjustment for both front
seats, driver's seat with memory feature
Seat covering N1A Leather seat covering
Seat heater 4A3 Seat heater for front seats
separately controlled
Shock absorption, chassis, front 1GD Front sports shock absorption
glass
equipment tires
Start/stop system/regenerative braking 7L0 Without inertia benefit system/
deceleration fuel cut-off/idle stop
valve
column
sequence control
Trunk sill protection 2P1 Plastic trunk sill protection
equipment
for rear axle
Wheel covers 1NH Full wheel covers
Wheels C6E Steel wheels 6J x 15
Offset 38
Wheels V17 Alloy wheels 7.5J x 17
circuit breaker
with rain sensor
PC5
PH3
PL1
PSR
PW2 nitro1989 napisał(a):jak da rade to moj tez by mozna by bylo sprawdzic vin VSSZZZ1PZ6R017303
Nr nadwozia VSSZZZ1PZ6R017303
model leon stylance
LE
Data produkcji 05.09.2005
Rok modelowy 2006
typ handlowy 1P1212
numer silnika BKC
numer skrzyni biegów GQQ
Wyposazenie BF
kolor dachu Z4
"Multimedia", video/DVD/notebook connection 9WC Without "Multimedia" in vehicle
(stone guard)
Additional child seat anchors 3B4 Child seat anchor for
child seat system ISOFIX
Additional warning lights 9TA Without additional warning lights
deactivation
Air duct, front area VK0 Air duct, standard
Anti-theft protection system 7AH Electronic vehicle immobilization device
with alarm system, passenger compartment
control and backup horn
Audio-response system/voice control QH0 Without voice control
Base engine T71 4-cylinder diesel engine 1.9 L
unit 03G.1
Batteries J1D Battery 380 A (72 Ah)
triangle
Brake type, front 1ZM Disc brakes, front (Geomet D)
Brake type, rear 1KD Disc brakes, rear
Child seat anchor, front 3G0 Without child seat anchor front (ISOFIX)
Chrome work package QJ0 Without aluminum/chrome work package
Climatic zones 0Y1 Standard climatic zones
Components with special surface appearance 6FF Body-colored exterior mirror housings
and various add-on parts
Control number (no PR-Family) S0C Introductory volume
electronic
Dashboard 4N3 Comfort dashboard
Door and side trim panels 3LD Door and side trim panel
Door pockets, front 3YB Door pockets, front
Doors 0A2 4 doors
Drawers under front seats QN1 Drawer under left front seat
Engine specifications D3W 4-cyl. turbo diesel engine 1.9 L/77 kW
Base engine is T71/TG0/TD0/T5X
Equipment levels A8M Executive comfort equipment
Exhaust tailpipe 0P1 Rear side exhaust tailpipe
Exterior noise suppression measures 2B2 Additional exterior noise suppression
triangle
Front seat, left 3TB Standard seat, front left
Front seat, right 3SB Standard seat, front right
Fuel filler cap/door, locking option 2W3 Fuel filler cap remote unlocking
Fuel systems 0F8 Cooled fuel system for diesel engine
Fuel tank treatment 2LD Fuel tank without differentiation of
special material treatment
(fluorination/co-extrusion)
General operating permit, alterations C02 Operating permit, alteration
Generators 8GU Alternator 140 A
Glove compartment 4Z4 Glove compartment door without light
Grab handles at roof frame 5N3 Folding grab handles
Headlight 8BG Twin-headlight for driving on the right,
with integrated high beam
Headlight activation 8K8 Low beam assistant with
"Coming Home" function
Heat accumulator system/additional heater 7E6 Electric auxiliary air heater
control free of cfc
Hill hold control UG0 Without hill hold control / hill descent
control / comfort driving assist
system
Insert for the filling up of unleaded fuel/fuel type 2G5 Filler neck module 1 without insert
transmission MQ 250
vehicle components
Instrument inserts U5A Instrument insert, km/h speedometer
Interior light in driver compartment 9GD Two interior lights with door pillar
switch and switch-off delay
Interior light in foot area 6T0 Without interior light in footwell
Left vanity mirror 4SM Left vanity mirror illuminated
with cover and pocket
Light package (lighting) QQ0 Without add. lights (interior lighting)
from outside
(unlockable)
Luggage compartment lining 5A7 Comfort trunk lining with service lid/
cover
front seats
Nameplates for sales name QD0 Without lettering for sales name
Operating voltage 9Z0 Operating voltage 12V
Outer rear seat belts 3ZB 3-point seat belts, outer rear with ECE
label
Paint coating FB0 Standard paint coating
Pedal cluster VF0 Standard pedal cluster
Pedestrian protection VL0 Standard pedestrian protection measures
Platform group class 7PH Platform group class 8
preparation
installation
Protective side molding 4B0 Without protective side molding
Quattro GmbH FQ0 Standard production wheels
Radiator grille 6KG Radiator grille
Radios 8YL Radio with CD player
Reading light 8S7 Two reading lights front
Rear fog light 8TC Rear fog light for driving on the right
Rear seats 3NZ Rear seat bench unsplit, backrest split
folding
Rear stabilizer 0BF Rear stabilizer
Refrigerator 1W0 Without refrigerator/glove compartment
cooling system
Remote-controlled garage door opener VC0 W/o remote-controlled garage door opener
Restraint systems, front 3QT 3-point seat belts with tensioner and
height adjustment, front
Safety certificate 0LA Without special plates/stickers/
safety certificates
Safety headrest system 3K0 Without safety headrest system
Scuff plates 7M0 Plastic scuff plates in door apertures
Seat belt check 9P1 Seat belt reminder, electric
contact in buckle
Shock absorption, chassis, front G48 Front shock absorption
Shock absorption, chassis, rear 1JA Rear shock absorption, basic design 1
Side air bag 4X3 Side air bag front with curtain air bag
Side and rear windows 4KF Side windows in heat-insulating glass,
from B-pillar and rear window dark
tinted
Smoking/non-smoking package 9JD Smoking package, ashtray front
Spare wheel/breakdown set 1G8 Breakdown set
Speaker installation 8RL 6 speakers (passive)
Special labels/plates 2KW Labels/plates in German, French, and
Dutch
Steering 1N3 Speed-related variable steering assist
(Servotronic)
Steering wheels 1MH Leather steering wheel
Storage compartment 4Y0 Without storage compartment/safe box
sequence control
Thermal insulation 4T0 Without thermal insulation
Tire pressure warning light 7K6 Flat tire indicator
Tires HH7 Tires 205/55 R16 91V
Trailer hitch 1D0 Without trailer hitch
Tray 7N0 Without tray on roof liner
Tray areas package QE0 Without tray areas package/box
TV reception/digital radio reception QV0 W/o TV reception/digital radio reception
Vehicle class differentiation units/platform components 0HJ Vehicle class differentiation 1P0
equipment
Washer fluid level indicator 8W0 Without washer fluid level indicator
Weight category front axle L58 Suspension range 58
Weight category rear axle 0YA Weight range 1
Wheels C2B Alloy wheels 6.5J x 16
circuit breaker
with rain sensor
PAB
PAD
PCO
PSR
romero-studio napisał(a):Poproszę o rozkodowanie numeru VIN SEAT EXEO ST Style rok. prod. 2010 2.0 TDI
VSSZZZ3RZAR017595
Wyniki FI w ramach katalogów sa propozycjami, których prawidlowosc i logicznosc nalezy sprawdzic.
parametry pojazdu
Nr wypos. podst.
Nr nadwozia VSSZZZ3RZAR017595
model exeo st sport
EX
Data produkcji 12.02.2010
Rok modelowy 2010
typ handlowy 3R54Q1
numer silnika CAHA
numer skrzyni biegów HCK
Wyposazenie GJ
kolor dachu Z4
"Multimedia", video/DVD/notebook connection 9WL Multimedia socket for external audio
source
deactivation
Antennas 8L4 Window antenna
Anti-theft protection system 7AS Anti-theft alarm system, passenger
compartment control, backup horn and
towing protection
Base engine TH3 4-cylinder diesel engine 2.0 L
unit 03L.B
Body style K8D Station Wagon Variant/Avant
Brake type, front 1LT Disc brakes, front
Bumper 2JZ Standard bumpers
Component part sets with country-specific design requirements B0N Component parts set, complying with
vehicle type for Great Britain, various
parts
Cruise control 8T1 Cruise control system (CCS)
Cruise control warning and speed limit system 6Y9 W/o cruise control speed limit system
Doors 0A2 4 doors
Double-size standard radio/dual-view display 2T1 Double-sized standard (DIN)
Drawers under front seats QN3 Drawers under front seats
Electric interface for external use UF2 Electric interface for external use
Emission standard 7MG Emission standard EU5
Engine specifications D93 4-cyl. turbo dies. eng. 2.0 l/125 kW 4V
TDI common rail
Base engine is TG3/TH3/TL4/TM4/TP4/TU3
Exhaust tailpipe 0P6 Rear exhaust tailpipe
triangle
Floor mats 0TC Front floor mats
Front seats Q1D Sports front seats
General operating permit, alterations C04 Operating permit, alteration
Glove compartment 4Z7 Glove compartment w. variable spacing
Handling standard production and pre-production series FA3 Internal control
Headlight 8BK Twin headlight for driving on the left,
Heating and air conditioning system 9AD Climatronic, free of cfc
Insert for the filling up of unleaded fuel/fuel type 2G0 Without insert for the filling up of
fuel
Inserts 5MB Decorative inserts
Installation parts for engine (engine mount system) 1VG Installation parts for four-cylinder
engine
Instrument inserts U1B Instrument insert with mph speedometer,
clock, tachometer and trip odometer
Left exterior mirror 5SJ Left exterior mirror: convex
from outside
Lockable wheel bolts 1PE Wheel bolts with anti-theft protection
(unlockable)
Luggage compartment floor covering 6SN Trunk protection insert
Luggage compartment lining 5A9 Luggage compartment lining
front seats
Moldings 4ZB Bright moldings
Multi-function display/trip computer 9Q2 Multi-function display/on-board computer
with check control
Nameplate set 1RQ Nameplate set "TDI"
Owner's manuals 0VF Information kit in English
Park distance control 7X1 Park distance control
Protective side molding 4B3 Protective side molding
Radios 8UD Radio "concert"
Rear cargo area 3GE Raised rear cargo area
cooling system
Roof rails/roof load rack 3S1 Bright roof rails
contact in buckle
Shock absorption/suspension, chassis 1BA Standard suspension/shock absorption
tinted
Ski bag 3X0 Without load-through provision
Smoking/non-smoking package 9JC Smoking package
Special labels/plates 0SS Labels/plates in English and French
(Servotronic)
Steering system arrangement L0R Right-hand drive vehicle
Steering wheels 2ZQ Leather trimmed multi-function steering
wheel for air bag system
Telephone/telematics 9W9 Car phone installation
Tie down straps/net/pocket 6M0 Without tie down straps/net/pocket
Tires H7D Tires 225/40 R18 92Y xl
Transmission types/gearshift mechanisms 0G1 Gearshift lever
Tray areas package QE1 Tray areas package 1
Type approval countries/countries with special requirements B09 Type approval Great Britain and Northern
Ireland
Vehicle class differentiation units/platform components 7KS Vehicle class differentiation 3R0
equipment
Versions FM0 Basic equipment variant
Weight category front axle 0JJ Weight category front axle
weight range 9
Weight category rear axle 0YK Weight range 10
Wheels C0J Alloy wheels 8J x 18
circuit breaker
Windshield glass type 4GJ Windshield in heat-insulating glass,
with viewing window for vehicle
identification numberlukastd napisał(a):Da radę ktoś odkodować:
VSSZZZ5PZ5R064820
Nr nadwozia VSSZZZ5PZ5R064820
model altea stylance
ALT
Data produkcji 21.12.2004
Rok modelowy 2005
typ handlowy 5P1231
numer silnika BKD
numer skrzyni biegów HDU
Wyposazenie DN
kolor dachu K3
kolor zewnetrzny / numer koloru K3 / S9N
(stone guard)
deactivation
Antennas 8ZE Roof antenna
Base engine T9G 4-cylinder diesel engine 2.0 L
unit 03G.A
Body style K8P MPV
triangle
Brake type, front 1ZE Disc brakes, front (Geomet D)
mirror
Controls (steering wheels/steering column) 4LB Radio control
electronic
Doors 0A2 4 doors
Engine specifications D3X 4-cyl turbo diesel engine 2.0 l/103 kW
16V (TDI) with unit-injector system
base engine: T9G/TB3/TM0/TP0/TC3/TQ0
Exterior mirror setting 6XV Exterior mirrors: electrically foldable,
triangle
Front seat, left 3TG Sports comfort seats front, left
Front seat, right 3SG Sports comfort seats front, right
Front spoiler 5L1 Front spoiler
Front stabilizer 0AF Front stabilizer
Fuel filler cap/door, locking option 2W1 Lockable fuel filler cap
Headlight activation 9C0 Without special headlight activation
mode but with "Coming and Leaving Home"
feature
control free of cfc
system
fuel
transmission MQ 350
vehicle components
from outside
(unlockable)
Luggage net/pocket on backrest(s) 4U5 Luggage pockets on backrest
front seats
label
Platform group class 7PJ Platform group class 9
preparation
installation
Reading light 8S5 Two reading lights front
Rear seats 5KQ Rear seat bench/backrest, split folding
Rear stabilizer 0BD Rear stabilizer
cooling system
Rough-road/sports version 2UC Sports version
safety certificates
contact in buckle
Shock absorption, chassis, front G42 Front shock absorption
Shock absorption, chassis, rear 1JC Rear shock absorption for sports design
tinted
(Servotronic)
sequence control
Tire pressure warning light 7K0 Without tire pressure warning light
Tray 7N2 Spectacle tray/bracket
Vehicle class differentiation units/platform components 0HT Vehicle class differentiation 5P0
equipment
Weight category front axle L62 Suspension range 62
Weight category rear axle 0YB Weight range 2
Wheels C7E Alloy wheels 7J x 17
circuit breaker
W14
tomasz_89 napisał(a):Proszę o pomoc w rozkodowaniu VIN: VSSZZZ1MZ5R033939.
Nr nadwozia VSSZZZ1MZ5R033939
model leon stella
LE
Data produkcji 15.10.2004
Rok modelowy 2005
typ handlowy 1M1324
numer silnika ASV
Wyposazenie KG
kolor dachu 1V
(stone guard)
rear
deactivation
indicator light
unit 038.G
triangle
adapter
mirror
Bumper 2JS Body-colored bumpers with protective
moldings
Control number (no PR-Family) S3W Pricing
electronic
and woven fabric
Doors 0A2 4 doors
EU 3
base engine is T8U
triangle
treatment
Gearshift knob/handle 6Q9 Leather gearshift knob/handle
General operating permit, alterations C26 Operating permit, alteration
soft fold-away
activation
control free of cfc
system
Inserts 7TH Decorative inserts
transmission MQ 250
vehicle components
radio reception
with remote control
from outside
(unlockable)
in seat backrests
on-board computer
design 2
installation
lights rear
seat
glass
equipment tires
column
sequence control
Tires H7F Tires 195/65 R15 91H
equipment
for rear axle
Wheels C2S Cast alloy wheels 6J x 15
offset 38
(1C0 601 025 F)
regulators rear
PMA skuraa napisał(a):Prosze o rozkodowanie mojego VIN VSSZZZ1MZ3R060466
Nr nadwozia VSSZZZ1MZ3R060466
model leon top
LE
Data produkcji 11.10.2002
Rok modelowy 2003
typ handlowy 1M1766
numer silnika ARL
Wyposazenie VN
kolor dachu Z4
partial trim plate
deactivation
indicator light
Base engine T20 4-cylinder diesel engine 1.9 L
unit 038.R
triangle
mirror
Country-specific product program X0A National sales program Germany
leather
Doors 0A2 4 doors
Engine specifications D3A 4-cyl. turbo diesel eng. 1.9 L/110 kW
TDI with pump-jet injection system,
base engine is T20/T9J
triangle
treatment
Gearshift knob/handle 7F0 Leather gearshift knob with titanium
appearance
General operating permit, alterations C18 Operating permit, alteration
soft fold-away
activation
control free of cfc
system
transmission MQ 350
vehicle components
radio reception
with remote control
from outside
(unlockable)
front seats
Nameplate set 0PU Nameplate set "TDI" (red, pump-jet
injection system)
design 2
installation
Seat adjustment 3L5 Electric seat adjustment for both front
seats
glass
mechanism)
column
Steering wheels 2ZG Leather steering wheel for air bag
system with mass damper
sequence control
equipment
Weight category front axle L44 Suspension range 44
for rear axle
Wheels CK5 Alloy wheels 7J x 17
circuit breaker
PH2
PL1
PW1 jar3k napisał(a):ja też jeśli można prosić
VSSZZZ1MZ3R128678
Nr nadwozia VSSZZZ1MZ3R128678
model leon cupra
LE
Data produkcji 16.04.2003
Rok modelowy 2003
typ handlowy 1M1516
numer silnika AMK
numer skrzyni biegów FML
Wyposazenie GX
kolor dachu 1V
partial trim plate
deactivation
indicator light
Base engine T6B 4-cylinder gasoline engine 1.8 L
unit 06A.G
triangle
Brake type, rear 2EM Disc brakes, rear
mirror
Bumper 2JP Bumper
Component part sets with country-specific design requirements B0J Component parts set, complying with
vehicle type for Italy, various parts
and woven fabric
Doors 0A2 4 doors
Engine specifications MK1 4-cyl. turbo gas. eng. 1.8 L/154 kW 20V
appendix EU 3
base engine is T6B
Exterior noise suppression measures 2B9 Additional exterior noise suppression
triangle
Front stabilizer 0AQ Front stabilizer
Front underbody guard 1SF Additional engine and transmission guard
Fuel quantity for initial filling 1Z2 Increase in initial standard fuel
filling
engine
treatment
appearance
General operating permit, alterations C21 Operating permit, alteration
soft fold-away
Hand brake lever handle 6PC Leather hand brake lever handle
activation
control free of cfc
system
transmission MQ 350
vehicle components
radio reception
Key for locking system 8QK Key for locking system
from outside
(unlockable)
in seat backrests
Nameplate set 0NA Without nameplate set
(without model designation)
Owner's manuals 0VG Information kit in Italian
Pillar lining 4XC Exterior pillar lining
installation
lights rear
seat
Shock absorption, chassis, front G92 Front shock absorption
Shock absorption, chassis, rear UA2 Rear shock absorption
glass
Spare wheel/breakdown set 1G3 Alloy spare wheel with original
equipment tires
Special editions E5K "Cupra R"
Special labels/plates 0SK Labels/plates in Italian
Steering QZ7 Power steering
column
sequence control
Tire suppliers V0D PIRELLI tires
Tires H3L Front tires 235/60 R18 103W
rear tires 255/55 R18 105W
Type approval countries/countries with special requirements B14 Type approval Italy
(San Marino, Vatican City)
equipment
Weight category front axle L05 Suspension range 05
for rear axle
Wheels CV4 Alloy wheels 7.5J x 18
circuit breaker
PBE KR16 napisał(a):bardzo proszę o sprawdzenie numeru VIN:
VSSZZZ1MZ6R016350
Nr nadwozia VSSZZZ1MZ6R016350
model leon stella
LE
Data produkcji 18.04.2006
Rok modelowy 2006
typ handlowy 1M13KC
numer silnika BCB
Wyposazenie BP
kolor dachu Z4
(stone guard)
Additional warning lights 9TC Additional reflectors (door area)
deactivation
indicator light
unit 036.L
triangle
adapter
mirror
and woven fabric
Doors 0A2 4 doors
triangle
Fresh air intake for passenger compartment (with particulate filter) 2V0 Fresh air intake without air cleaner
engine
treatment
General operating permit, alterations C31 Operating permit, alteration
Grab handles at roof frame 5N2 Folding grab handles at roof frame
activation
control free of cfc
system
transmission MQ170
vehicle components
radio reception
with remote control
from outside
in seat backrests
design 2
installation
Radios 8AA Without radio
lights rear
Rear headrests 3Q1 Rear headrests
seat
glass
equipment tires
column
system
sequence control
equipment
for rear axle
Wheels CT8 Alloy wheels 6J x 15
circuit breaker
PA5
PW1
komoornik napisał(a):A da radę rozkodować VIN Leona 5F z 2013 roku?
VSSZZZ5FZER050612
Nr nadwozia VSSZZZ5FZER050612
model leon fr
LE
Data produkcji 31.10.2013
Rok modelowy 2014
typ handlowy 5F15UX
numer silnika CHPA
numer skrzyni biegów NBJ
Wyposazenie CP
kolor dachu I4
kolor zewnetrzny / numer koloru I4 / W5P
"Charism" 2H5 Driving profile selection and
conventional shock absorber
Air bag 4UP Driver's and front passenger air bag
with knee air bag and front passenger
air bag deactivation
Alternative drive module 0K0 Without alternative drive module
Antennas 8ZH Antenna for AM/FM reception, "diversity"
Base engine TL1 4-cylinder gasoline engine 1.4 L
unit 04E.A
Batteries J0S Battery 320A (59Ah)
Braking systems 1AZ Electronic stabilization program (ESP)
Camera systems/accident sensors KA0 Without camera systems/accident sensors
Camera/distance sensor QK0 Without camera without distance sensor
(driver assistance system)
CD/DVD drive and SD card slot EC3 With CD drive and SD card slot
Chrome work package QJ3 Chrome package
(type 2)
Compass/traffic sign display QR8 Without traffic signs recognition
Component part sets with country-specific design requirements B0A Component parts set without
electronic
Customized installation FC0 Without customized installation
Dashboard 4N2 Standard dashboard
Delivery equipment 2A0 Without delivery equipment
Differential lock 1Y3 Differential lock (XDS)
dynamic traction control
Door and lid locking system 4I2 Radio remote controlled central locking
operated from inside without safe lock
Door and side trim panels 3LJ Door and side trim panel in foam film,
insert in leatherette
Doors 0A2 4 doors
Driving on the left/on the right AV1 Driving on the right
ECO function for driving profiles and drive select EF1 ECO function
Electric interface for external use UE4 Electric interface for external use
AUX-IN and USB
Emission standard 7MJ Emission standard EU5 plus
Engine specifications DF6 4-cyl. SI engine 1.4 l/103 kW
TSI
base engine is TL1/TK8
Equipment levels A8H Top sports equipment
Extended safety system 7W0 Without extended safety system
triangle
Folding table 1U8 W/o folding table on front seat backrest
Fresh air intake for passenger compartment (with particulate filter) 2V5 Fresh air intake system with activated
charcoal canister
Front Assist 6K0 without Front Assist/without city
automatic emergency braking
Front fog light/additional headlight 8WH Front fog lamp and cornering lamp
Fuel systems 1A5 Fuel system for fuel-injected engine
General operating permit, alterations C07 Operating permit, alteration
Handling standard production and pre-production series FA0 Control of standard production
Headlight 8IT LED headlamps
Headlight activation 8K3 Separate daytime running lights with
low beam assistant and "Coming Home"
feature
Headlight-range adjustment 8Q3 Automatic headlight-range adjustment
dynamic (self-adjusting while driving)
Headrests 5ZF Front headrests
control free of cfc
Hill hold control UG1 Hill hold control
Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
transmission MQ 250
vehicle components
Interior light in foot area 6T4 Interior light in footwell
Light assistance system 8G0 Without light assistant
cover
front seats
Multi-function display/trip computer 9S5 Multi-function display/on-board computer
"Medium"
label
Owner's manuals 0VT Information kit in Polish
Paint preservative/transit coating 5K7 Transport protection film (minimum
protection) with additional transport
protection measures
Parking brake UH0 Parking brake
installation
Radios I8A Entry radio (Gen1)
Reading light 8S4 Two reading lights front, two rear
Rear fog light 8TB Rear fog light
Rear headrests 3T2 Three rear headrests
Rear seat catch UK1 Standard rear seat release
folding
Rear spoiler 5J0 Without rear spoiler
Rear stabilizer 0BA Without rear stabilizer
Refrigerant KK1 Refrigerant R134a
cooling system
Regional code for radio ER1 Regional code " ECE " for radio
Rest Assist EM0 Without Rest Assist
Scuff plates 7M3 Scuff plates in door apertures
Seat belt check 9P3 Seat belt reminder, electric contact in
buckle
Seat covering N0V Fabric seat covering
Service indicator QI6 Service indicator 30,000 km or 2 year
( variable )
Shock absorption, chassis, front G02 Front shock absorption
tinted
Side assist/lane departure warning 7Y0 Without lane change assistant
Smoking/non-smoking package 9JA Non-smoking package
Spare wheel/breakdown set 1G6 Space-saving spare wheel
Start/stop system/regenerative braking 7L6 Start/stop system with regenerative
braking
(Servotronic)
Steering wheels 2PF Leather trimmed multi-function sports
steering wheel
Subsequent guarantee EA0 Without subsequent warranty
Taillight assemblies 8SK Taillight assemblies with diodes (LED)
Telephone/telematics 9ZX Mobile phone preparation
Tire pressure warning light 7K1 Tire pressure warning light
Type approval countries/countries with special requirements B17 Type approval Poland
Vehicle class differentiation units/platform components 7LF Vehicle class differentiation -5F0-
equipment
Vehicle tracking system 7G0 Without preparation for VTS
(vehicle tracking system)
Weight category front axle L11 Suspension range 11
Weight category rear axle 0YD Weight range 4
Wheelbases 0B1 Wheelbase
Wheels C0U Alloy wheels 7.5J x 17
circuit breaker
Windshield wiper intermittent control/ light/rain sensor 8N6 Windshield wiper intermittent control
with light/rain sensor
PLP
PSS Aeki86 napisał(a):prosze o rozkodowanie numer vin VSSZZZ1PZ9R505105
Nr nadwozia VSSZZZ1PZ9R505105
model leon stylance
LE
Data produkcji 06.04.2009
Rok modelowy 2009
typ handlowy 1P1233
numer silnika BKD
numer skrzyni biegów LQW
numer napedu osiowego 6A
Wyposazenie EN
kolor dachu Z4
"Charism" 2H0 Without "drive select"
(stone guard)
deactivation
Anti-theft protection system 7AJ Electronic vehicle immobilization device
with alarm system and backup horn
unit 03G.A
triangle
Climatic zones 0Y2 Tropical zones
Country codes FE0 Without country code (no DVD player in
vehicle)
electronic
Dashboard 4N0 Standard dashboard
Doors 0A2 4 doors
Electric interface for external use UF6 Electric interface for external use
(MDI)
Engine cooling system 8Z4 Moderate hot country
triangle
Front stabilizer 0AD Front stabilizer
Headlight 8JW Twin headlight for driving on the right
(gas discharge) w/ integrated high beam
feature
Headlight-range adjustment 8Q6 Headlight-range adjustment, automatic/
dynamic with fixed and dynamic bending
light(AFS 2)
control free of cfc
Installation differentiation for vehicle components 0ES Installation differentiation for
transmission DQ250
vehicle components
from outside
(unlockable)
cover
front seats
with check control
Nameplates for sales name QD1 Nameplates for sales name
label
Owner's manuals 0VD Information kit in Spanish
preparation
installation
Radios 8YM Radio with CD player (high-end)
folding
cooling system
safety certificates
buckle
Shock absorption, chassis, front G51 Front shock absorption
tinted
Special labels/plates 2KY Labels/plates in Italian, Spanish and
Portuguese
(Servotronic)
Steering wheels 2FL Leather trimmed multi-function steering
wheel with Tiptronic
sequence control
Transmission specifications G1A 6-speed automatic transmission
Type approval countries/countries with special requirements B15 Type approval Spain
(Andorra, Balearic Islands, Canaries)
Upgrading measures GP4 Vehicles with special upgrade measures
equipment
Weight category front axle L50 Suspension range 50
Weight category rear axle 0YC Weight range 3
Wheels F33 Alloy wheels 7J x 17
circuit breaker
with rain sensor
PAB
RB5
WTE albertbubu napisał(a):Witam
proszę o rozkodowanie numer vin VSSZZZ1PZ6R094446
Nr nadwozia VSSZZZ1PZ6R094446
model leon stylance
LE
Data produkcji 04.05.2006
Rok modelowy 2006
typ handlowy 1P1212
numer silnika BXE
Wyposazenie BF
kolor dachu 9M
kolor zewnetrzny / numer koloru 9M / S3H
(stone guard)
passenger
unit 03G.1
triangle
Controls (steering wheels/steering column) 4LC Radio and telephone controls
vehicle)
electronic
Doors 0A2 4 doors
triangle
General operating permit, alterations C06 Operating permit, alteration
control free of cfc
transmission MQ 250
vehicle components
from outside
(unlockable)
cover
Lumbar support 7P5 Manually adjustable lumbar support for
left front seat
with check control
label
preparation
installation
folding
cooling system
safety certificates
seat
buckle
tinted
(Servotronic)
sequence control
equipment
circuit breaker
with rain sensor
PAK
PCO
PFU
PG0
RB5
milosh napisał(a):Proszę i rozkodowanie VINu
VSSZZZ1MZ1R015256
Nr nadwozia VSSZZZ1MZ1R015256
model leon signo
LE
Data produkcji 28.07.2000
Rok modelowy 2001
typ handlowy 1M1824
numer silnika ASV
Wyposazenie AX
kolor dachu 7D
(stone guard)
passenger
indicator light
unit 038.G
triangle
adapter
and woven fabric
Doors 0A2 4 doors
EU 3
base engine is T8U
triangle
treatment
soft fold-away
activation
control free of cfc
system
transmission MQ 250
vehicle components
radio reception
with remote control
Lashing rings/rails for load restraint 6B0 Without lashing rings for load restraint
from outside
in seat backrests
design 2
preparation
installation
lights rear
Shock absorption, chassis, front G24 Front shock absorption
glass
equipment tires
column
system
sequence control
equipment
for rear axle
Offset 38
circuit breaker
with rain sensor
Tominjo napisał(a):Jak da radę to z góry dzięki.
vsszzz1mz3r039597
Nr nadwozia VSSZZZ1MZ3R039597
model leon stella
LE
Data produkcji 26.07.2002
Rok modelowy 2003
typ handlowy 1M1324
numer silnika ASV
Wyposazenie KG
kolor dachu 1G
kolor zewnetrzny / numer koloru 1G / S5S
(stone guard)
rear
deactivation
indicator light
unit 038.G
triangle
adapter
mirror
moldings
CD changer/CD player 7A2 CD changer
various parts
and woven fabric
Doors 0A2 4 doors
EU 3
base engine is T8U
triangle
treatment
soft fold-away
activation
system
transmission MQ 250
vehicle components
radio reception
with remote control
from outside
(unlockable)
in seat backrests
on-board computer
design 2
installation
seat
glass
equipment tires
column
sequence control
equipment
for rear axle
regulators rear
P81
RB4
K121 napisał(a):Bardzo bym prosił.
vsszzz1mz4r023000
Nr nadwozia VSSZZZ1MZ4R023000
model leon top
LE
Data produkcji 30.07.2003
Rok modelowy 2004
typ handlowy 1M1736
numer silnika AUQ
Wyposazenie UV
kolor dachu Z4
partial trim plate
deactivation
indicator light
unit 06A.C
triangle
Component part sets with country-specific design requirements B0F Component parts set, complying with
vehicle type for Switzerland, various
parts
leather
Doors 0A2 4 doors
turbo
triangle
engine
treatment
appearance
soft fold-away
activation
control free of cfc
system
Inserts 5TQ Decorative titanium inserts
transmission MQ 350
vehicle components
radio reception
with remote control
from outside
(unlockable)
front seats
design 2
installation
seats
Seat covering N7N Alcantara/leather seat covering
glass
mechanism)
column
sequence control
Type approval countries/countries with special requirements B13 Type approval Switzerland
equipment
for rear axle
circuit breaker
with rain sensor
PC4
PH2
PL3
PSR
s_t napisał(a):Poproszę o sprawdzenie.
Dzięki i pozdrawiam.
VSSZZZ1MZ2R020572
Nr nadwozia VSSZZZ1MZ2R020572
model leon stella
LE
Data produkcji 11.07.2001
Rok modelowy 2002
typ handlowy 1M13KC
numer silnika AZD
Wyposazenie GF
kolor dachu 3D
(stone guard)
rear
passenger
indicator light
unit 036.L
triangle
adapter
mirror
Bumper 2JB Standard bumpers
parts
and woven fabric
Doors 0A2 4 doors
triangle
Front fog light/additional headlight 8WA Without front fog light
engine
treatment
soft fold-away
Headlight 8BF Halogen headlight for driving on the
left
activation
system
transmission MQ170
vehicle components
Instrument inserts U0L Instrument insert with tachometer
clock and mph speedometer
radio reception
with remote control
from outside
(unlockable)
Luggage net/pocket on backrest(s) 4U2 Luggage net on backrest, left seat
in seat backrests
on-board computer
design 2
installation
Right exterior mirror 5RV Right exterior mirror: aspherical
Seat covering N7B Fabric seat covering
glass
equipment tires
Special labels/plates 0SC Labels/plates in English
column
system
sequence control
Ireland
equipment
for rear axle
regulators rear
