bzykofm napisał(a):Sprawdź, powinien być BT. Spróbuj wyszukać BT telefonem manualnie. Pytanie jakie radio. Zintegrowany BT miały tylko RNS 315 i sporadycznie 310(to fabryczne nawigacje).
https://www.google.com/search?q=rns+310 ... e1TfOGa7iM:
Press the microphone button on your steering wheel
Say Say Name (chyba miało być "save name")
You will hear "the name please"
Say the name then you will be asked the number
Say number slowly and clearly it's then repeated back i think!!
Then say Save or store cant remember
repeat for all numbers you want to use via voice control
Then to make a call press microphone button say SELECT NAME you will be asked the name say name you will then hear your voice saying that name then say dial and it should work
