VCDS-Lite Version: Release 1.0
Thursday, 15 December 2011, 04:59:32:0
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01,02,03,08,15,17,19,22,35,36,37,46,56
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 036 906 034 CP
Component and/or Version: MARELLI 4MV 4376
Software Coding: 00031
Work Shop Code: WSC 12345
Additional Info: VSSZZZ1MZ2R074012 SEZ7Z0A1411004
2 Faults Found:
16686 - Cylinder 2: Misfire Detected
P0302 - 35-10 - - - Intermittent
P0302 - 35-00 - -
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.LBL
Controller: 1C0 907 379 J
Component: ABS FRONT MK60 0103
Coding: 0001025
Shop #: WSC 00001
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Controller: 1C0 909 605 A
Component: 1L AIRBAG VW51 0A 0004
Coding: 12620
Shop #: WSC 06441
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: Redir Fail!
Controller: 1M0 920 802 A
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 04106
Shop #: WSC 00000
2 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06441
1 Fault Found:
Address 46: Central Conv. Labels: 1C0-959-799.LBL
Controller: 1C0 959 799 E
Component: 2U Komfortgerát HLO 0003
Coding: 00067
Shop #: WSC 06441
3 Faults Found:
01044 - Control Module Incorrectly Coded
35-00 - -
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-10 - Implausible Signal - Intermittent
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
Address 56: Radio Labels: 1J0-035-18x-56.LBL
Controller: 1M0 035 186 D
Component: Radio 0001
Coding: 00401
Shop #: WSC 06441
1 Fault Found:
00852 - Loudspeaker(s); Front
36-10 - Open Circuit - Intermittent
End --------------------------------------------------------------------------------------------------
