Instrument Cluster 32-pin Connector (Green) Terminal Identification
#1-#16 right side from up to down
1.) open
2.) open - reading coil for immobilizer 1 (from 05.99 prod.)
3.) open
4.) open - data bus (CAN), shielding for input (from 05.99 prod.)
5.) W-wire (where applicable)
6.) low level washer fluid
7.) brake pad indicator
8.) external buzzer - open from 05.99 production
9.) open
10.) fuel reserve warning - open from 05.99 production
11.) signal for vehicle stationary
12.) air conditioning system cut-off - ECT signal
13.) parking brake indicator light (K14)
14.) warning light for traction control / vehicle stability
15.) open
16.) open
#17-#32 left side from up to down
17.) open - reading coil for immobilizer 2 (from 05.99 prod.)
18.) open - oil temperature and oil level warning signals
19.) open - data bus (CAN), high input signal (from 05.99 prod.)
20.) open - data bus (CAN), low input signal (from 05.99 prod.)
21.) open
22.) open - input signal from hood alarm switch (from 05.99 prod.)
23.) MFI call up button - top (display switches forward)
24.) MFI call up button - bottom (display switches backward)
25.) MFI memory switch - reset
26.) ambient air tempertature sensor
27.) open - data bus (CAN), high output signal (from 05.99 prod.)
28.) open - data bus (CAN), low output signal (from 05.99 prod.)
29.) open
30.) output signal 2 from electronic speedometer - open (from 05.99 prod.)
31.) selector lever display - open (from 05.99 prod.)
32.) fuel consumption signal - open (from 05.99 prod.)
Instrument Cluster 32-pin Connector (Blue) Terminal Identification
1.) terminal 15, positive
2.) right turn signal indicator light (K94)
3.) output signal 1 from electronic speedometer
4.) open
5.) fuel gauge (G1)
6.) airbag malfunction indicator light
7.) terminal 31, sender ground (GND)
8.) engine coolant temperature gauge (G3)
9.) terminal 31, ground (GND)
10.) oil pressure switch (F1)
11.) RPM signal - open from 05.99 production
12.) generator warning light (K2), terminal 61
13.) glow plug indicator light (K29 - diesel only), control light for rear seat backrest lock from 05.99 production (only certain countries)
14.) open
15.) open
16.) warning light for rear lid open (only certain countries)
17.) headlight high beam indicator light (K1), terminal 56a
18.) left signal indicator light (K54)
19.) ABS warning light (K47)
20.) instrument cluster illumination, terminal 58b
21.) signal for open driver's door
22.) engine coolant level (ECL) sensor (G32)
23.) terminal 30, (B+)
24.) terminal 31, ground (GND)
25.) on-board diagnostic (K-wire)
26.) parking light right, signal for "lights on" warning buzzer
27.) parking light left, signal for "lights on" warning buzzer
28.) speedometer vehicle speed sensor (VSS) (G22)
29.) warning light for brake system fluid level
30.) ignition key warning buzzer, terminal 86s
31.) seat belt warning system
32.) emission workshop lamp (only certain countries) - open from 05.99 production
Mam taki pin out o seata. Czy chodzi Ci o pin nr. 29 z zielonej kostki?
A od audi taki
http://inhoss.cba.pl/aaa/6.pdf
